How can I get Clara.io Visualiser to use a "wood" material?
john_smith077
Member Posts: 175 ✭✭✭
Hello
Is there any way to import additional materials (e.g. wood) to the Clara.io Visualizer app?
If so how do we do this?
Background
I just want to do some "quick and dirty" visualizing so that I can see very roughly what my model will look like in some new materials (e.g. Wood) that does not come as standard with Clara.io Visualiser.
I'm very keen not to learn an entire new application. The full-blown Clara.io seems rather intimidating...
Thanks
J
Background
Thanks
J
In proper editor you'll have vray library:
Don't hesitate to use full Clara.io
Michał
projektowanieproduktow.wordpress.com
Not only did I find the Clara.io editor to be it deeply counter-intuitive, but also the messaging is either non-existent or unhelpful.
e.g. I don't mind that rendering some things is time consuming, but there is little/no feedback to tell you that it is attempting to do something.... and the suddenly without warning BANG it has applied some material you selected 3 minutes ago.
Likewise, unlike in Onshape when an item that is selected changes colour to orange, there was little or no feedback to tell me when I had actually selected something in Clara.io. Nightmare.
And when I changed the environment first time it worked, second time nothing happened.
I can see that it's probably extremely powerful but I don't want to spend (waste?) my time learning something this complicated.
I JUST want to see roughly what my model would look like in brushed steel & some kind of dark wood. If there was some way to get additional materials (e.g. a couple of choices of dark wood & a brushed steel) that would be all I need. (i.e. I dont want to hear about complicated backgrounds or lighting conditions)
Images bellow were made within 5-7 min (setting up and render):If you will need I can help start.
Re UV data - I barely understand what that means. Something to do with texture it seems. [For now I'm trying not to get too sucked into the world of 3D rendering as it looks pretty complicated. I just want to choose some simple combinations of materials and see what they would look like in normal/average lighting conditions...]
OK here is a public document which I'll share for a few days:
https://cad.onshape.com/documents/56b133f2e4b07682577e734a/w/833e61fc4db3414bec7491f2/e/89865db9f9db908a554513c2
On images above there are some glitches, but only because I didn't take time to finish them.
Do I take it that the above were generated in Lagao itself rather than within an Onshape plugin? (if that's a meaningful question!)
Many thanks
J
P.S. Meanwhile it looks increasingly like I'm going to have to try to find the time bite the bullet to watch some official Lagao training videos... [sigh]
(it's just that I'm v tight on time to properly learn all this! )
This time I've change UV projection to simplest one and resaults are best for now:
It might be a good idea to focus our attention to one of the 5 existing rendering partners already available in the app store vs adding a 6th that is not in the App Store? Since after all this is the App Store forum
Both Maxwell and Keyshot will handle wood very well.
I did this is in 3 clicks.
1. Open (1 click), model
2. Drag 2 different wood materials (2 clicks)
3. Hit render... Ok it was 4 clicks.
It is an easy workflow, accessible to any Onshape user right now. I used Keyshot BTW... And I used PowerSurface for the modeling of the can....
PowerSurface
Keyshot
I can't find any such option on the File menu within KeyShot. [GRRRR! ]
Could you possibly tell me how to connect to Onshape?
Also please confirm that it is not a time-bombed trial.
J
EDIT:
Wait - I just spotted that on this page (https://www.keyshot.com/onshape) it says "If you do not currently have a paid license of KeyShot, you will be offered a free 14 day trial." That is NOT what I call free. Get me out of here.
Also PowerSurface talks about a "Free monthly usage plan" - which sounds like free use only for one month. Nope that is a deal-breaker.
To explain: I will only be using these rendering applications rather occasionally and I do not want to be locked out of the system without paying what will add up over a year to a huge sum, and that on top of the time I have wasted trying to learn them. No chance in Hell.
CONCLUSION
So unless I can work out out to import wood materials into the Clario app (without going into Clario proper) ... I guess that takes me back to Lagoa even though it's not an Onshape app. [sigh]
@michał_1 - Btw, a small request - your images are great but they are a full 8MB each and are murdering my bandwidth. For next time any chance of adding a little compression?
Just to be clear:
It is the connection to Onshape (within KeyShot) itself which is free. The Connection still requires a licensed KeyShot installation.
It is included in any of these versions:
- KeyShot 6.1 HD
- KeyShot 6.1 Pro
- KeyShot 6.1 Pro Floating
- KeyShot 6.1 Enterprise
So if a free rendering app is what you're looking for, then KeyShot is not for you.However, we do have great support for pushing updates from changed models and different workspaces into KeyShot.
Dries
www.keyshot.com
Thanks for the comments. Looks like PowerSurface should more clearly describe what they offer. Since I think you made the wrong assessment.
PowerSurface gives you a fully functional product with up with up to 30 surfaces..... That covers a lot of geometry. I covers the model I showed. I think you should be very happy with that. If all you need is 30 surfaces or less, looks like you have a great solution. If you need more, upgrade. if you then need less later, downgrade... You can't really ask for a more reasonable offering IMO.
Many of the apps in the App store are brand new. I'd just check back in a short amount of time. Nothing you asked for should require to you go to a 6th option. So check back soon.
Joe
Which version are you running? The Connection was not included in the 6.0 release of KeyShot.
If you are running the 6.1 Demo, then you should see 'Connect to Onshape...' under File.
Btw, I suggest you update to the latest version (6.1.72, just released today...) by downloading from here or here. This version has a critical fix for importing Onshape assemblies.
Dries
www.keyshot.com
Win64: https://www.keyshot.com/?ddownload=329833
Win32: https://www.keyshot.com/?ddownload=329832
Mac: https://www.keyshot.com/?ddownload=329834
Let me know how it works.
dries@luxion.com
Dries
www.keyshot.com
Dries
www.keyshot.com
Can you get in touch with our support?
support@luxion.com
Dries
www.keyshot.com
It'd be great to know if you like the KeyShot + Onshape combo.
Dries
www.keyshot.com
