Drawing Exporting DXF Issues
caz_waskowicz
Member Posts: 2 ✭
in Drawings
I have an issue exporting an Onshape drawing for a vendor to waterjet. My vendor uses BobCAD and Mastercam and cannot see the geometry in my exported drawing in either program. I'm thinking this has something to do with how Onshape handles "model" and "paper" space and which it exports to? --- there aren't any options when exporting, it just does it.
I work with this particular vendor a lot at my job where we use Solidworks. I send my vendor .dxfs all the time from Solidworks without issue. Any ideas?
(only thing I found that works is going to a part studio and exporting the face of the part I want to a .dwg and then manually compiling all my faces in a 2D cad program---would like to just be able to export the Onshape drawing instead)
Thanks,
Caz
Thanks,
Caz
https://cad.onshape.com/documents/667b1d08d8bb4689a96d7f20/w/2d510f8a8fe041c2a40ada5f/e/ad19616f1fece60ecb5ddb85
Here wass his response:
I was able to open this file on one of our newer software packages but the file came in pretty bad. All the arcs were generated with short straight lines and also did not define the arc very well. They were choppy.
I'm not sure what software he's using, and I'll find out, but this is a considerable set back for me. I love Onshape, especially its browser based platform. But, after putting in 50+ hrs self training, this is an extremely disappointing discovery.
In Drawings, does the "Refine Graphics" have any effect on the dxf export? Any suggestions?
Thanks,
Michael
The DWG or DXF export from Onshape drawings is still using graphical "proxy objects" instead of basic AutoCAD entities. The proxy graphic objects in the DWG/DXF can be exploded (if you have the right software) but exploding results in short segment polylines which sounds like the problem you are seeing.
For CAM-friendly DWG/DXF output from Onshape today you'll need to export the face of your 3D model to DWG/DXF instead of exporting the drawing. In the Part Studio select the face and right-click. Select Export as DXF/DWG from that menu. This DWG/DXF output will give you nice clean arcs.
If you want to send the drawing too (with the dimensions) you could use PDF for that or just explain that there are two types of DXF/DWG files you are sending. The Part Studio exported DXF/DWG should work great with OMAX Layout.
The differences between these versions are mostly related to drawings.
