Offset dimension for solved sketches
Is it possible to create offset sketches for solved and/or imported sketches?
    The bad news: Not easily. Onshape sketch tools (like offset) just generate code for a large number of low-level operations, so the "offset" behavior isn't encapsulated in a FeatureScript function. In order to do a proper offset, you'd have to start with a constrained unsolved sketch, create a sketch entity of the correct type to match every old sketch entity, constrain them all using an offset constraints, then solve. Not impossible, but certainly lots of somewhat tricky work.
    The good news: Support is much better right now for doing this in 3D. You can query for the edge faces of an extrude, and perform an opThicken() on those faces. The resulting faces will be offset from the originals just like a sketch entity would be with sketch offset. Using extrudes, thickens, and booleans, it's likely that you can get the functionality you want without making any additional sketch entities.
