Help needed creating a hidden Bayonet fitting inside a tubular cylinder
john_smith077
Member Posts: 175 ✭✭✭
Hello
Can anyone give me any helpful pointers as to how to tackle this?
I am trying to create a sort of 'bayonet fitting' inside a cylinder. (In fact more of a double-bayonet)
i.e. I need to cut a trench into the inside surface of a cylinder. This trench would include both verticals and diagonals, and would be for a stud to track along.
VERY roughly it would look something like this:
I'm not sure where or how to start!
i.e. I don't know how to cut a trench parallel to a curved surface...
e.g. Are there parts of any videos I should watch?
Many thanks
J
EDIT: I have annotated screenshot further. Hopefully now slightly clearer...
Many thanks
J
If you need your inside cylinder to rotate while translating in/out of the cylinder, then you need to sweep a profile sketch along a helix, as outlined in this thread: https://forum.onshape.com/discussion/comment/14958#Comment_14958
The 'trench' in the above diagram has vertical sections and diagonal sections. It needs to track around the inside surface of the female part staying at a consistent depth as measured from the curved inside surface of the Female part.
