Where on earth is the small cube?
LeeBeeLeeBee Member Posts: 7
Hello,
I posted yesterday about drawing views & was pointed towards the help page with the different options of shaded, translucent etc. This help page talks about a small cube - now I've looked at some of the training videos & they have a small cube below the view cube which I do not have. Where do I turn this on? Having all sorts of trouble sketching & hoping the options found within the small cube will make things easier.
Thanks,
lee
  • jon_mcintyrejon_mcintyre Onshape Employees Posts: 56
    The small cube is available to you when using part studios and assemblies, but not drawings.   Are you looking for it in a part studio and not seeing it there?
  • LeeBeeLeeBee Member Posts: 7
    edited February 2016
    Thanks Jon,
    Not really up on the terminology that you guys use but I'm drawing my part. I've drawn a 2.5mm hole then tried to linear pattern it up and across but only certain ones show - wanted to change the view to see if it helps but can't find it. Have attached a picture as an example.
    Thanks,
    lee
    Are you working on a supported browser? (Internet Explorer and Edge are not supported): See https://cad.onshape.com/help/Content/webgl.htm
    If you're seeing this on a supported browser please raise a support ticket via the help menu --> feedback.
    Thankyou - schoolboy error on my part I'm afraid as I was using Edge. Now tried in Chrome and everything is working as it should do!
    Thanks for the assistance  B)
