sketchings in 3D?
Hi,
I'm new to onshape and I would like a wireframe of a pyramid (not solid one
which can be made with the loft cmd) For the base I have a circle
extruded along a square. But how can I get into the
height?
pi
height?
pi
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
Pi - not sure exactly what you're looking for, but this should get you going in the right direction
https://cad.onshape.com/documents/672037842438121da6a58da4/w/2a32e9a41cc863f9fc09d1a7/e/6500938b95083602753da705
Philip Thomas - Onshape5 -
Pi - in most solid modeling systems, planes can be created to meet sketching needs.
In this model, plane 1 was defined using 3 points and allowed us to draw the path between the base and the apex.Philip Thomas - Onshape5
means how to rotate sketch plane 3?
Plane3 was created normal to the line that goes from the corner of the base to the apex of the pyramid.
You can pick up the rollback bar and step through the regeneration of the part studio feature by feature.
But how is the apex created? I wasn't able to sketch anything that isnt in the sketch plane (groundplane of pyramid)...
Pi
