Is it possible to have feature definitions toggle depending on whether a query is emtpy?
I want to do something like this:
IE, i want to provide some other inputs, but only if the user has entered a query that selects things.
I tried
but it appears that even when the user selects nothing, we get an empty query, not undefined ( unfortunate )
i know i can do this too:
but it kind of stinks beause the user has more clicks:
definition.selectedBodies is Query;
if ( isQueryEmpty(definition.selectedBodies ) ){
definition.someOtherProperty is boolean;
I tried
if ( definition.selectedBodies != undefined ){
definition.doYouWantToDoWhatever is boolean;
if ( definition.doYouWantToDoWhatever ){
ilya_baran Onshape Employees, Developers, HDM Posts: 1,232
Yes and no.
No, it's not possible to predicate inputs on query resolution (the way you can on enums or booleans) because changes unrelated to the feature can make a query resolve differently. For instance, a feature deleted earlier in the history can make a query that was previously empty resolve to something non-empty, which would cause a precondition error in the feature.
Yes, you can work around this (and save user clicks) with an editingLogicFunction. You could even make the doYouWantToDoWhatever boolean hidden with a UIHint but then the user could end up stuck in the wrong state with no obvious recourse. Let me know if you need more info on how to do this.
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
