I want to make a static mixer inside a cone
phillipp_pals
Member Posts: 6 ✭
Good Morning,
I'm new to cad in general and have been playing around for a week. Now I'm busy with my application for the Design Academy and I need some help.
I want to 3d print something that looks like the inside of this tube (static mixer) but in a conic shape.
The furthest I came was a spiral.
Thanks in advance.
Thanks in advance.
OK how about now? (open link above)Senior Director, Technical Services, EMEA6
Is this what you're after?
https://cad.onshape.com/documents/e94235809ef0b69d4481bb44/w/27c841085bb2517b09959502/e/d11ec7b02d0fac5099ab1986
Senior Director, Technical Services, EMEA0 -
excactly like that!
Thank you1 -
okay so I didn't want to ask again because I should be able to figure it out myself, but how do I change the dimensions of this thing? I can only get it wider.
It needs to be about 280 mm high and 80 mm wide at the base and 15 mm at the top. I'm sorry0 -
oh and has to be slit in half so I'm able to print itphillipp_pals said:okay so I didn't want to ask again because I should be able to figure it out myself, but how do I change the dimensions of this thing? I can only get it wider.
It needs to be about 280 mm high and 80 mm wide at the base and 15 mm at the top. I'm sorryNeilCooke said:OK how about now? (open link above)
If you edit each feature in turn you will see there will be a dimension controlling each size. To split it into two create a plane and use the split command. If you really get stuck let me know.Senior Director, Technical Services, EMEA0
I think I needed some rest, I got it the way I want it.NeilCooke said:If you edit each feature in turn you will see there will be a dimension controlling each size. To split it into two create a plane and use the split command. If you really get stuck let me know.
1
