Extruding from a Second Perpendicular Sketch
joseph_fournierjoseph_fournier Member Posts: 17
Hi,
I have extruded a Part from a first sketch. I have afterwards created a second sketch on one of the surfaces (created by the extrusion), which is perpendicular to the first sketch plane. I am trying to extrude a component of that second sketch but without success.
 How can I achieve this?
 Thank you. Regards,
 Joseph
  • ryan_thiessen999ryan_thiessen999 Member Posts: 12
    Do you possibly have the wrong add/new/remove/etc selected?  Can you share a link to your document?
    The people here (myself included) cannot resist fixing stuff. If you post a public link, someone (if not me) will have that sorted lickety split!
    Thank you for your support of Onshape.
    Philip Thomas - Onshape
    edited March 2016
    @joseph_fournier , I think you have created second sketch on face which is not parallel to first sketch plane. You need to perform two separate extrude operation for this. Kindly refer below video for more detail.
    If Your case is different then kindly share your document with us.
