about mate orientation
donald_8donald_8 Member Posts: 40 ✭✭
does it make a difference which way the mate is?  Z is the blue one and i will use it here. part 1 the blue line is pointed to the right and part 2 the blue line is pointed to the left when i mate them together. part 1 is a 4x4 flat steel and part 2 is 6x6 flat steel and i 'm mating them in the center
  • shanshanshanshan Member Posts: 147 ✭✭✭
    can not understand your question clearly, could you explain it in details?
  • donald_8donald_8 Member Posts: 40 ✭✭
    so i would align them so that all 3 axis are the same to make it easier to set limits and offset. do all 3 axis need to be aligned or one?
