<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
about mate orientation
donald_8
Member Posts: 40 ✭✭
does it make a difference which way the mate is? Z is the blue one and i will use it here. part 1 the blue line is pointed to the right and part 2 the blue line is pointed to the left when i mate them together. part 1 is a 4x4 flat steel and part 2 is 6x6 flat steel and i 'm mating them in the center
By and large, when mates are done they will be moved to align/anti-align the blue axis with as minimal re-orientation as possible. Aligning them beyond that helps do things like limits and offsets but isn't necessary.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
By and large, the blue axis is the only important one. The x-y alignment can usually be changed easily with the quadrant command which makes it secondary.donald_8 said:so i would align them so that all 3 axis are the same to make it easier to set limits and offset. do all 3 axis need to be aligned or one?Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
thanks5
can not understand your question clearly, could you explain it in details?0
so i would align them so that all 3 axis are the same to make it easier to set limits and offset. do all 3 axis need to be aligned or one?0
thanks5
