How can I create an array-path?
             Narayan_K
                            Member Posts: 379 ✭✭✭
                    @ Nick_B , At this stage you can't make this in one option (like pattern along path) in Onshape.But you can achieve it by using linear and circular pattern. Narayan_K
 You have to make linear pattern to travel along line and for last instance(which starts turning) you have use transform to rotate part then circular pattern for travel along the curve.
 5
Please go there and give it and upvote. The more upvotes a request gets, the more likely it will get implemented.
