creating quick 2D drawings
colin_daly
OS Professional Posts: 40 ✭✭
in Drawings
I want to make a sketch in a part studio, and then create a drawing of just that sketch without having to make an extrusion first. Other than exporting a DWG file and then re-importing it into a drawing, is there an easy way to do this?
Your method of export DWG/DXF of the sketch and import as a drawing is the best way to do it. Of course this drawing will not have associativity to the part studio sketch.
When you see a white background, it's indicating that there's virtual "paper" there. If you zoom out you'll see the edge of the sheet, as determined by the sheet size. You'll see a sheet name in the upper left box. To switch between sheets, or from "Model Space" to sheets, press the sheets toolbar button, and pick in the sheet dialog.
