opPlane, what are height and length relative to?
dave_cowden
Member, Developers Posts: 480 ✭✭✭
export function opPlane(context is Context, id is Id, definition is map)
I expected that 'length' and 'height' are always relative to the x and y directions of the defined Plane.
However, i've found that they do not behave this way. Instead, the height and width seem to be based on something else.
Consider this code:
const HEIGHT = 0.02;
const WIDTH = 0.04;
const plane1 = plane ( vector(0,0,0), vector( 1, 0, 0 ), vector( 0, 0, 1) );
opPlane(context, id + "plane1", {
"plane": plane1,
"width": WIDTH,
"height": HEIGHT
const plane2 = plane ( vector(0.05,0,0), vector(1, 0, 0 ), vector( 0, 0, 1) );
opPlane(context, id + "plane2", {
"plane": plane2,
"width": WIDTH,
"height": HEIGHT
The difference between plane1 and plane2 is the direction of the x axis. I expect the height or the width to be consistently oriented along the x axis of the plane, but both of the above codes give the same result visually:
It appears that the height and width are relative to something other than the orientation of the plane?
Explicit and intelligent plane alignment is crucial to good parametric design. I hope we get it soon!
