query any of a long list of entity/geometry types
adamohernadamohern Member, OS Professional Posts: 216 PRO
I would like my input query to allow the user to select a face, plane, edge, or sketch entity. How do I allow all of these at once?
I've noticed that the bitwise OR operator "||" works if you use two only two criteria, but breaks down if you try to do more than two.
    Hmm. The following works fine for me:
    annotation { "Name" : "My Query", "Filter" : GeometryType.LINE || GeometryType.PLANE || SketchObject.YES, "MaxNumberOfPicks" : 1 }
    definition.parameter is Query;
    Would you mind posting an example of the || operator failing, for the sake of trying to reproduce the bug?
  • adamohernadamohern Member, OS Professional Posts: 216 PRO
    Good to know. Not sure what I was doing wrong. Rather than try to reproduce whatever problem I was having I'll just try to move forward and see if I can get it to work. Thanks!
