How to Use Circular Pattern
 cheyenne_greatorex
                    Member Posts: 2 ✭
cheyenne_greatorex
                    Member Posts: 2 ✭
                    I am trying to model a vented brake disc.  I completed the basic design and got the point where I wanted to fillet the intersection between the ribs and the inside surface of the rotor disc.  Filleting one is easy, but I want to fillet the rest automatically.  I thought that I would be able to use circular pattern to propagate the fillet to each rib, but the tool just reports an error.  I also tried using the tool on the faces, but that didn't work either.
Is what I want possible or am I just going about it the wrong way?
I tried another solution. Instead of creating the ribs using a circular pattern, I used an extrude to cut a whole in the brake disc. I filleted that hole and I was able to use circular pattern to replicate the hole and its fillets all the way around. The problem with this design is that the ribs aren't rectangular, they're trapezoidal, because the extrude creates the void between the ribs rather than the ribs themselves.
I tried a variation on my second solution, I chamfered the extruded hole. This got me pretty close, but I had to guess at the angle needed to make the chamfer so that the ribs would be rectangular. I made an additional sketch to help me try to figure out the exact angle, but it didn't turn out right and the ribs are still a little wider at the bottom than at the top.
I've learned a lot, but have more to go, and any help or insight would be greatly appreciated. I feel like either this is a hard problem to solve, or I'm missing an obviously easy way to go about it.
Here's the model in question...
https://cad.onshape.com/documents/e97d7a489fb5bd5e60fc78d8
