convert solid part to surface body?
adamohern
Member, OS Professional Posts: 216 PRO
If I have a solid body and would like to convert it to an empty surface body (i.e. stitched faces), how can I do that? I know I can use delete face to remove one face, thus converting the rest of the body to surfaces, but I want to do it without removing a face.
1
shashank_aarya
Member Posts: 265 ✭✭✭
@adamohern At this point of time there is no direct method available but as a workaround you can use "Hollow shell" as given below.
5
