transform rotate around axis
adamohern
Posts: 216 PRO
opTransform(context, id + "transform1", {
"bodies" : qCreatedBy(id + ("profileSketch")),
"transform" : transform({
"transformType" : TransformType.ROTATION,
"angle" : definition.axialRotation * degree,
"transformAxis" : ???
I want to rotate a sketch around its z axis. I was hoping that the above would get me there. For the purposes of this thread, let's assume I was correct in my approach.
Note that "transformAxis" wants a Query. I don't have a transform axis. It would be trivial to create a Line using the sketch plane's origin and normal, but I don't think I can query that (can I?). A workaround is to create a sketch on a perpendicular plane, add a line to it, then query that line. This seems like a lot of runaround for something so simple. Is there a better way?
The problem here is due to confusion between transform the feature and functions to create an actual transform. The opTransform documentation has some examples you can use -- one of them (the one you want) is using rotationAround, which takes a Line and an angle:
const zAxis = line(vector(0, 0, 0) * meter, vector(0, 0, 1)); opTransform(context, id + "transform1", { "bodies" : qCreatedBy(id + ("profileSketch")), "transform" : rotationAround(zAxis, definition.axialRotation) });
Note that if you asked for definition.axialRotation in the precondition using isAngle, you shouldn't multiply by degree (because it's already an angle).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
Oh dear. What did I miss? I just double-checked and didn't find any examples in the source or reference. Where are they?0 -
Ah, my bad -- I was looking at the not-yet-released version of the library -- we have a number of documentation improvements on the way.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2
