zero length parameter?
adamohern
Member, OS Professional Posts: 216 PRO
It appears that zero length parameters are not allowed. Is that true? I realize I could use a boolean value or something to effectively zero out (and remove) the length, but this adds an extra control that I'd rather not have cluttering up my UI. Is there a way to add a zero length that I'm just not seeing?
However, there's more bounds available in the valueBounds module. If you replace LENGTH_BOUNDS for a particular parameter with NONNEGATIVE_ZERO_INCLUSIVE_LENGTH_BOUNDS or even NONNEGATIVE_ZERO_DEFAULT_LENGTH_BOUNDS then zeros are golden. You can also make your own LengthBoundSpec if you have more particular needs.
The docs on LENGTH_BOUNDS actually looks wrong now (It say it allows zero, but that's only true when you call the feature within FS, not in the UI). I'll fix.
