offset sketch curves
adamohernadamohern Member, OS Professional Posts: 216 PRO
Is there a way to offset sketch curves? Could I do it for an entire region all at once?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,263 image
    There is not a direct way.  Easiest way is probably to extrude the sketch region and then thicken the non-cap faces.
  • adamohernadamohern Member, OS Professional Posts: 216 PRO
    Okay, thanks.
