Creating a Part Using Circular Pattern Tool
I have created a gear wheel with thirty teeth, using the circular pattern tool to replicate one tooth in sketch. I have then tried to use it in an assembly, but am having trouble. When I try to use a mate to connect it to an axle, only one tooth will attach: the rest are left behindandneed to be mated indivudally.
I assume that I am doing something wrong, but how can I make the gear a single entity and not several?
Thank you.
James.
Thank you.
James.
