opPattern IDs
Are there individual IDs for each copy made with an opPattern? I tried
qCreatedBy(id + "opPattern_ID" + "instanceName")
, but that didn't seem to work. The documentation says, "TODO: make it easy to query for them," regarding the instanceNames parameter, so is this not possible yet? 0
ilya_baran Onshape Employees, Developers, HDM Posts: 1,231
Yes, that doesn't work because a pattern is one operation so one id. You can try to reverse engineer the automatically generated ones, but like the TODO says, we need to make this easier.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5 -
jacob_kingery Member Posts: 39 EDU
I was able to work around the issue by doing each transform separately myself instead of patterning them all at once. Once it's easier to make use of the instance names, it might be better to switch back to using opPattern().5
