How do I view a cross section of my model?
I want to see the internal structure of my parts. What's the best way to view or display the inner structure of a part in Onshape?
scott_harris
Moderator, Onshape Employees, csevp Posts: 66
After you cut or split your part(s) you can suppress the cut/split to get back to your original "view".
Scott Harris / Onshape, Inc.5
This discussion has been closed.
Go to the end view of your model. Create a sketch of the shape you want to cut away (arc, rectangle, etc.) Extrude that sketch, select "Remove" to cut away the part you don't want, and check "Merge with all." That will remove the material from the model to reveal your cutaway view.
I'm new to the forum and to Onshape. I'm testing it to assess whether we could use it in my company.
So here my first comment: It is cumbersome to cut or split or remove material to get a cross-section view of your part... Hopefully an option will soon help to do this.
