"UIHint" : "OPPOSITE_DIRECTION" Does not work if placed next to query fields
adamohernadamohern Member, OS Professional Posts: 216 PRO
Is this a bug? If I add the "UIHint" : "OPPOSITE_DIRECTION" flag to a boolean field that occurs immediately after a query field, it only appears momentarily in the dialog before being covered up by the query field, never to be seen again. It works fine next to length or enum parameters.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    Yes, this is a bug -- we've linked you to it.
