Can you insert a dxf in the mobile version.
nick_carternick_carter Member Posts: 1
i am new to onshape and cannot find the icon in the mobile version. Can it only be done from the we browser version
  • cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
    @nick_carter You can import a DXF into a Document using the Onshape iOS app. However, you cannot yet insert a DXF into a sketch using the Onshape Mobile app. Hope that helps.
    To clarify this: you can import files to create a Document in the Onshape iOS app.  There is not a way to import files into an already existing Document from the Onshape mobile app.
