working with FeatureList objects
adamohern
Member, OS Professional Posts: 216 PRO
I want to allow my user to select a previously created feature, then build something using that feature as an input. I assume I need to use a query for FeatureList objects, but I'm not sure how to handle them once I have them.
Let's say I have a feature called "VertexGenerator", and another called "LineGenerator" that accepts VertexGenerator features as inputs. How would I get the vertices generated by the selected VertexGenerator features for use in drawing the lines?
annotation { "Feature Type Name" : "Point out points" } export const show = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { 'Name' : 'Feature' } definition.f is FeatureList; } { var queries = []; for (var f in definition.f) queries = append(queries, qCreatedBy(f.key, EntityType.VERTEX)); const q = qUnion(queries); debug(context, q); });
