Extrude Issue
tony_valente
Member Posts: 1 ✭
Hi,
I'm having problems with an extrude function. I'm trying to extrude a bunch of letters brought in through an EPS file (EPS - DWG - Import to Onshape). I can extrude all the letters but the N. For whatever reason the N will not let me extrude as a solid; only each side, but not the face.
I've tried redrawing the N with constraints and that didn't help.
Any suggestions?
Thanks
Tony
Any suggestions?
Thanks
Tony
The written answer is that other than telling you to make sure that all the endpoints are coincident, there is close to zero chance of diagnosing this from just a screenshot.
