Best way to construct a shaft
bert_fouriebert_fourie Member Posts: 102 PRO
Any advice on the best way to construct a shaft - it has two bearings plus a gearbox and some other part fitting to it.
Do i start with a sketch with the circles and then extrude and transform each section, or is there a better way? In free form modeling I would have positioned all the parts, then do a line sketch in cross section to fit the parts in their final positions, I would then revolve the sketch into a solid shaft.
  • bert_fouriebert_fourie Member Posts: 102 PRO
    Thanks, I agree, this is the way I like to do it also.
