Spiral Challenge
chrisjh777chrisjh777 Member Posts: 209 ✭✭✭✭
I used kevin_o_toole_1 's spiral workaround here:
https://cad.onshape.com/documents/c526017c3b894f329b22c776/w/a189b5aba46e4e78a5fa6ecd/e/9474fe11c7f540f4a5752185
to create my Archemedean spiral in this design, but could not work out how to truncate the centre of the spiral sketch.
How do I edit the spiral sketch so it doesn't start at the centre?  I need this to be a part (polypropylene pipe), not surfaces as shown here.  The part could not be generated because the centre of the spiral results in self intersection.
I created this part some years ago using an equation driven curve in Solidworks, but would like to do the same in Onshape.  The equation driven curve allowed numeric start and finish points, hence getting around the self intersecting issue I am seeing here.
Link to my design here:  https://cad.onshape.com/documents/573310b3e4b0adc280b6ea15/w/9f9abe291a41c1703816f9e9/e/f03932ea02c1c06e61380b31
Thanks in anticipation.
