Drawing circle cuts hole in plate
I have a square plate (i.e., square shape I've extruded to 1/8" thick). I want to create a protrusion from the surface of the plate. When I draw a circle on the surface of the plate, however, all it does is cut a hole in the plate. My understanding is that I need to draw a circle, then an offset, then extrude that "ring." What am I doing wrong? By the way, the plate is extruded below the plane and I'm drawing the circle on top of the plane.
Thanks,
Jay
Thanks,
Jay
may be this helps ...
After drawing the circle in the Sketch use the Extrude command with following settings:
Solid -> Add -> Blind - Opposite direction
https://cad.onshape.com/documents/3e9dacb5e2033879c501ee04/w/13691e67dc4453b7e9ea7c24/e/797882bb5a9fe84727fae974
after creating the circle then open extrusion #1 and add the inner area to the sketch regions list. then just create your new extrusion/protrusion by selecting the inner sketch region only.
_Dave_
Good point. I forgot that you use one sketch for multiple extrusions.
_Ðave_
