shape scaling option in a sketch.
mor
Member Posts: 10 PRO
Is there a shape shrink/enlarge (scaling) option in a sketch? (same geometry relations, different size)
viru
Member, Developers Posts: 619 ✭✭✭✭
@avshalom_mor, Currently scaling of sketch is not available in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape. Till time you You can use below work around for this issue.
create relationship for dimension by using variable feature. Kindly refer below video which will be helpful in dimension creation by using variable.
5
