how can I delete a document completely?
kurt_2kurt_2 Member Posts: 1
I want to get rid of several parts and leave no trace of them.
  • cadmandocadmando Member Posts: 68 ✭✭
    Send it to the TRASH BIN, then delete them from the trash bin - GONE
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,237
    One thing to keep in mind is that if you or someone you shared the document with linked to your document, than the links will continue to function even if the linked document is deleted.  This is because our principle is to not break existing part studios, versions, etc.  So to really leave no trace you may have to delete the linking documents also.
