Many points and skFitSpline
darren_13
                    Member, Developers Posts: 120 PRO
                    Hi I am automating a profile connecting many points with skFitSpline and the resulting spline misses most of the points specified.
                        the snippet of code is as follows:
                skFitSpline(sketch1, "camberSpline", {
                "points" : pointsCamber
where pointsCamber is an array of many vectors.
any ideas as to how i could improve this
also is there an way to specify an additional point to end this spline on? such as one specified by the user? this is needed as the points are automated using an equation apending the co-ordinates to the pointsCamber however doesn't accurately finish at the final required point thus leaving an opening in the created face. (the profile is an aerofoil)
https://cad.onshape.com/documents/95877be3b17f49277e87a2c3/w/c312c5dc50237be412236044/e/0652608a5a941e4062f7e896
thanks,
Darren Lynch
From what I can see, the reason you're seeing gaps is just the viewer being imperfect. The graphic data displayed for splines is just a piecewise approximation of what the actual shape is underneath (and there are performance reasons why you can't just always display a more accurate version).
The real spline that is parametrically part of your model actually passes through those points, you just can't see it as such.
Best,
Kevin
