Weldments
Hi, are there plans to implement weldment functionality similar to solidworks by having a library of shapes that follow sketch paths and also create a cut list showing types of profiles and cut lengths? In solidworks it's a single part file with multiple solid bodies. You can also have sheet metal incorporated into the weldment and extract flat patterns.
2
cyclonewade OS Professional, Mentor, Developers Posts: 53 ✭✭✭
Several of us have requested this type of functionality in previous posts. I certainly hope it comes around sooner than later. Onshape will no doubt need sheetmetal and weldments to chase down and convert many of us dual CAD to a single CAD users.imagine.create.deliver7
And this is a shame, because I absolutely love the feature set behind OnShape's cloud based system. I have all the faith in the world in the team that founded SolidWorks, and the collaboration, version control, and all the other benefits of OnShape are amazing. However until the feature set when it comes to the actual CAD workflow improves, I simply can't switch over. It's not even a choice. I'd go out of business.
