How do you get faces cut out by opSplitFace
dave_cowden
Member, Developers Posts: 483 ✭✭✭
Suppose I start with a face, like definition.someFace. I have found that if I do this:
opSplitFace(context, splitFaceId, {
"faceTargets" : definition.someFace,
"edgeTools": edgeTools,
"direction": surfaceTangentPlane.normal
debug(context, qCreatedBy(splitFaceId, EntityType.FACE) );qCreatedBy(splitFaceId) does not return any results.
What I expected to get was the faces that were stamped out by the cutting tool.
Instead, after opSplitFace, I find that definition.someFace now returns all of the faces. qNthElement(definition.someFace,0) returns indeterministic results.
What I want to get is a reference to the faces that were 'cut out' by the edges. But I cannot find out a good way to do that.
Any suggestions?
I also tried qDependency hoping that the stamped out faces woudl be a dependency of the original edges, but that did not work.
