Does a rectangle in a sketch directly define a Face?
paul_sorensen
Member, Developers Posts: 3 ✭
Does a rectangle in a sketch directly define a Face in Onshape, or does it have to be made part of another entity to become a Face?
paul_chastell
Onshape Employees Posts: 127
Any closed region in the sketch, which can be visually identified by being slightly gray and opaque, can be used almost anywhere that a face is needed. They are effectively planar faces of surfaces, and so if a face of a solid part is needed they won't be usable. Given that the sketch creates those faces after the position of the geometry is determined the sketch itself does not see its own faces while positioning the geometry, though it can see and use faces created by earlier sketches.Paul Chastell
TVP, Onshape R&D1
TVP, Onshape R&D
