3D splines can't be extruded or lofted
jaschaaajaschaaa Member Posts: 21 PRO
It seems that 3D splines created in FeatureScript can not be extruded or lofted to create solids with them. When drawing closed curves with opFitSpline I can't even select them in the Extrude command.
I am doing something wrong?
    I have swept along a 3D spline from this tool with good effect.
    (I believe extrude currently only supports "extrude normal to surface" but will have more functionality added later.)
    Cheers, OS.
    Cheers, OS.
    I can use a 3D spline as a sweep path too. However, selecting them in the loft function does not work... :(
