Part name and properties
emagdalenaC2i
Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭
Can we get and set the part name and their properties
Un saludo,
Do you mean like you set the material on a sketch profile and then when you extrude it the resulting part will have that material? That seems doable, but we have not thought about that... Or did you mean something else (like something with the user profile)?
Say I am building a desk, and I have numerous leg profiles. I would like to be able to have a library of leg profiles and be able to name each of them (leg1, leg2, leg3.....) This would be a tremendous help for BOM. It would also eliminate the possibility of typos.
We just need a stock material/items section built into Onshape that is also compatible with properties for BOM's.
