Design pattern to create a 3D object from a 2D ground plan
baumar
OS Professional Posts: 76 PRO
Hi,
I would like to ask a question and introduce the concept of "design patterns", that is learning and issue with a simple example.*
create a pyramid from a base plane to a given peak point, as I sketched in Pyramid https://cad.onshape.com/documents/294778f0f2aa9b816d4bccca/w/a87bbbd68e49f2f904fb13c9/e/ad9abb1ee3b6ca4b82398cf7
The four sides of the pyramid should be separate identical parts.
To create the faces of the pyramid, the outer line has to remain constant, whereas the other to lines have to stretch.
I tried to add another transformation, like scale or distance, but that didn't stretch properly-
Would you know an elegant way how to do that?
(I was hoping to find a kind of "smart extrude" allowing to pull up the middlepoint and then cut the solid body with diagonal planes, but I didn't manage...)
* The idea is based on "design pattern" (cf https://en.wikipedia.org/wiki/Design_pattern ). Simplified a design pattern offers solutions or solutions strategies to a common design problem.
Design patterns were originally created for architecture and found a large expansion in software programming.
I guess it could also give valuable contribution to a design tool like onshape.
Another influence for this are learning bits. They're also used IT, where a complex software is explained in small units or tutorials describing the usage of just one function or aspect of the software.
Optionsdaniel_splawski Member Posts: 66 ✭✭No worries boss.
I've updated the model in my original post to create the 4 identical non-overlapping parts that you were looking for. I used to Extrude>Remove commands to cut away the excess material from the top and bottom edges (Extrude 3 and 4) of the original part and then I used a circular pattern to duplicate/rotate the part to create the other three sides. Because each part is identical by definition, the circular pattern method of duplicating the parts will save a lot of hassle in the long run.
5
I'm not too familiar with the transform feature, so I don't know if there's a way to make it work the way you want it to.
https://cad.onshape.com/documents/5789465ce4b0e65410fa6595/w/05ecf63c6975a11a3565d407/e/793b8182c82d56976954d119
Thanks a lot for your fast reply!
If I get it right the solution you suggest is:
Create a plan with the 2 corner points and the peak point, design the triangle and then extrude it.
Then repeat it for all 4 surfaces.
I have done this in https://cad.onshape.com/documents/57895170e4b0dbf8509d319c/w/3391396343760f852f755d39/e/05d526af86fb1a355436cb59
It has the bottom of the triangle inclined and not yet even to the surface and the tip will have to be manipulated, that should not be too hard.
But eventually there should be 4 equal parts, here they are just overlapping. And I'm not shure how to do that...
(I'm sorry for not having written clear, I added it now)
brilliant, that's 2 flies in one swoop...
thanks a lot!
PS I wished I was your boss
If ever you are looking for a job to assist and review my design, let me know !-)
Are you saying the corner points do not match the lines in the sketch called "groundplane" and thus the planes are not right and thus the extrusions? But I don't see the error rsp how to fix it...
Do you know why they don't coincide - rsp what to do that they do coincide?
I tried to match the corner points with the lines in the sketch groundplane, but either it remains undefined or gets overdefined.
Would it help to set a point at each corner in the ground sketch?
Thanks a lot for your valuable help, boss !-)
Cheers
Markus
