How to pass parameter to skRegularPolygon "centre"?
Hi guys.
Sorry to be asking trivial questions.  I feel like a toddler again.
I'm trying to set the center point for a polygon on a recently created sketch as follows:-
It looks like the evVertexPoint returns a 3D vector where as the polygon is looking for a 2D vector.
                           var sketch1 = newSketchOnPlane(context, id, {
                           "sketchPlane" : evOwnerSketchPlane(context, {
                                "entity" : definition.targetpoint
                           var startPosition is Vector = evVertexPoint(context, {
                                "vertex" : definition.targetpoint
                            debug(context, startPosition);
                             skRegularPolygon(sketch1, "polygon1", {
                                    //"center" : vector(0, 0) * millimeter,
 Duff bit>>                    "center" : startPosition,
                                    "firstVertex" : vector(0, FeatureWidth/2) * millimeter ,
                                     "sides" : 6
error message is "Precondition of skRegularPolygon failed (is2dPoint(value.center))"
the debug yields sensible looking 3d coordinate values so I think we're good to that point.
With the incorrect "center"  set back to a vector (0,0) * millimeter the code executes fine with the polygon placed about the origin.
Any help appreciated.
Cheers,
  • john_f_carrjohn_f_carr Onshape Employees Posts: 74 image
    is2dPoint checks for a point in two dimensions but you passed a point in 3 dimensions.  You may need to project onto the sketch plane.
    Thanks guys, that worked perfectly.
    Much obliged.
