How to put a radius on an extrude???
I have been scratching my head for a couple of minutes and I thought maybe someone with some more sense would have the solution.. The image on top show a theoretical radius across the entire extrusion. The second image is attached for perspective only. Thanks in advance!!
mahir Member, Developers Posts: 1,317 ✭✭✭✭✭
Have you tried just extruding the radius sketch to cut off the extra material on top? You'll have to edit the sketch to make a closed contour. If what you need is a surface rounded in 2 dimensions, then you can use a revolved cut.5
