how to evaluate extrude direction so it can be used in a transform
Hi folks.
Hopefully an easy one this time.
I'm creating a body using an extrude from a sketch.
Having made it I may wish to transform it in the direction of the previous extrude operation.
I can use the qCreatedBy query to grab the body for the entity parameter but am having difficulty evaluating the extrude direction for the "transformDirection" parameter.  (If we can't use the extrude direction can we use "normal to the sketch" the extrude was performed with?)
if (definition.SubFlush)
                            transform(context, id + i, {
                                    "entities" : qCreatedBy(id + i + "extrudeNutDown1", EntityType.BODY),
                                    "transformType" : TransformType.TRANSLATION_DISTANCE,
 >> Here>>                   "transformDirection" // Evaluate The direction of the extrude in (id + i + "extrudeNutDown1") ,
                                    "distance" : SubflushExtraDepth * millimeter
I think this is the last line of fs code preventing this widget working properly so any help appreciated.
Cheers,
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    Can you query for the feature that created a body or surface? If you can locate the extrude, then the extrude direction is a vector property of that extrude's definition map. Or... I'm just talking out my ass.
    Thanks for your input chaps.  It's working now :-)
    As ever there are many ways of getting to the same end result, I was missing an obvious one.  All useful to learn from so nothing wasted.
    Thanks,
