View Cube in Safari
GWS50
GWS50 Member Posts: 532 PRO
The View Cube has disappeared. I'm on an iMac running El Capitan and using Safari.
It seems to re-appear when I switch to Firefox.
Anyone have a clue why this should be?
Many thanks
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,020 image
    Do you have Ad Block Plus or Ghosery plugin installed.. only in safari?
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • GWS50
    Yes Ghostery...I'll take a look at the settings.
  • GWS50
    Interestingly turning Ghostery seems to make no difference. The cube is there though because when I click in that area the view changes but it is just invisible
  • tim_martin786
    tim_martin786 Member Posts: 10 ✭
    If I remember... I think I experienced this a while back. What ended up "fixing" it was powering down and rebooting. (believe it or not) I rarely reboot my iMac since it awakens from sleep so conveniently and I never think about it. Sometimes months pass before cold starting the machine. Could be a small memory leak in Safari that causes this issue. I'm running El Capitan and Safari with Wipr extension.
  • GWS50
    Thanks Tim, I'll give it a go. I'm the same, I hardly ever restart the iMac
  • GWS50
    Still no luck! Uninstalled Ghostery completely and still not showing
  • daniel_splawski
    daniel_splawski Member Posts: 66 ✭✭
    Do you have any other extensions installed for Safari?  With Chrome I've had issues caused by an app called Zoomy
  • GWS50
    No nothing in the extensions. It is odd because the mouse arrow doesn't high-light the object below it until I move off to the side so could that be a graphic problem?
  • tim_martin786
    @GWS50, What is your version of Safari?
    I'm using 9.1.1 currently, but was having other odd browser behavior when highlighting text in a prior version.
  • GWS50
    using 9.1.2 Firefox works fine so I guess I'll stick with that for now
  • GWS50
    Interestingly I've discovered that when I reduce the window width the view cube reappears, strange!
  • robroy
    robroy OS Professional Posts: 3 PRO
    I'm using the latest fully optioned 2017 15" Macbook Pro.
    I see the view cube disappear in Chrome when I make the window full-screen on my external monitor (display scaled to 3360 x 1890)
    Interestingly the view cube stays in the right place and fully visible when the window is full width but only 2/3 or so of the full height, then as you continue to drag down the bottom edge of the window the view cube progressively slides right and out of view...
    Was this a driver problem or something else?
  • NeilCooke
    @robroy - that's hard to say - does it do it on the native Mac screen? I can't reproduce that on my system, but then my max external monitor res is 2560x1440. Does it also do it when you maximise Chrome full screen? What about Safari?
