Sweep a tubular shape through multiple planes?
don_whitmire968don_whitmire968 OS Professional Posts: 21 PRO
edited August 2016 in Community Support
I have spent the past day or so trying various methods of creating a cylinder that will bend and live in various planes. Just feel like there must be an easier way to get much better results.
    Have you tried a sweep along a the example featurescript 3D spline tool?
    Regards,
    Owen S
  • don_whitmire968don_whitmire968 OS Professional Posts: 21 PRO
    I have not.  I will investigate to find a tutorial and give it a shot.  Thanks for the help..
    Wow...this is a pain..  Any other ideas on how else to make a connected tubular, segments or continuous, multi plane component?  Any guidance on how to sketch in multi planes as well?
    We might be able to help you better if you posted an example of the types of geometry you're trying to achieve (hand-drawn if you can't get it in Onshape at all).  I assume the "pain" is creating the points through which the 3D spline needs to pass or is it something else?
    Ok, so I am working on a new tool that has an offset handle component that is living in 3 planes from the origin.  The finished result would be completely fixed and machined from a single billet.  The base of the handle where it interfaces with the tool would be a rectangle and then sweep into a round cylinder further up the handle, none of which is the issue.  The issue is being able to sketch and build in all 3 planes with a single wire sketch.  The "pain" was in reference to using the FeatureScript to make this happen.
    I am needing to figure out how to draw individual sketched line segments in different planes, joining those lines together and then sweeping a shape to run consistently from one end to the other.
    How would someone draw out a hard line hydraulic assembly with all of the bends without having to segment multiple pieces together?  If there was even a way to sketch this all out in a 2D flat, then sweep the overall shape and then mate to the part to the main component with a angled interface I could make that work even.  This is just really frustrating thats all.
  • michael3424michael3424 Member Posts: 736 ✭✭✭✭
    You might get more help if you publicly share your file, not just the screen grab.
