How do I sweep a complex curving path while staying perpendicular to surface?
tim_martin786
Member Posts: 10 ✭
I have managed to project a spiral path onto the inside of a bowl surface. So far so good. Now I'd like to sweep (I think) a line along that path and have it stay perpendicular to the bowl. The result should create a twisting spiral surface inside the bowl. Anyone have an idea how to accomplish this? Appreciate any feedback! Thanks!
Here is what I have so far: BowlSpiral
mahir
Member, Developers Posts: 1,317 ✭✭✭✭✭
Check out Part Studio 3. I used a loft with multiple profiles and one guide curve. It's tedious to setup the first time, but it should rebult well if you tweak the bowl shape. The large number of profiles is so the inner portion of the loft remains spiral-shaped. Generating a second guide curve isn't possible as you know. This behavior should be supported in FeatureScript since there is a normal to surface option in the opSweep command, but it doesn't seem to work well.
@ilya_baran, any input on getting the normal to surface option to work in FeatureScript? I have a failed attempt at a custom feature in this same link.
https://cad.onshape.com/documents/a05aeff75e42296533f07199/w/3da90aff92f27b413a5f9fdd/e/1b69c22e4b6baa26f6c30545
5
https://cad.onshape.com/documents/57a0685fe4b00f18b475be73/w/51c670c4273a5bafa29edd8a/e/0b7fc6cd953c0376bb3f7eb1
I was hoping there was someway to constrain the sweep line relationship normal to the bowl surface, but I guess not.
Since the bowl shape is likely to be modified often during our R&D development, it would be desirable to have the spiraling vane adjust "automagically" when changes are made to the basic shape... another reason I backed down from creating the second curve for a loft.
The "f" in "lockFaces" needs to be capital
Really appreciate the help! FeatureScript is definitely something I'll need to look into further as I become more proficient with things.
Thanks again! And thank you @jon_sorrells for the assist!
It appears that the construction line is a two-point spline with pierce constraints to the top circumference of the bowl, and it also seems to be coincident with the bowl surface in the sketch plane, and I guess that is the shown constraint. However, for the life of me I can't figure out how that constraint is applied, and it is bugging me. :-)
