Remove Fillet from Imported Part
shai_perednikshai_perednik Member Posts: 56 ✭✭
I imported a motor mount from F360 as an IGES file and it works fine in OnShape.  But I need to make some modifications to it now and the filet is causing issues.  How can I remove/delete these Filets?
This is what happens when I try to move the faces with the holes 5mm:
(note that I have to uncheck re-aply filet otherwise the move face doesn't work)
Doc and Part @ https://cad.onshape.com/documents/14f3d01d62b5237f728896c5/w/40e0afc950b8ca0dfecf9ef8/e/c73c19d03e00c868691a2625
1.PNG 122K
2.PNG 140.6K
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 186
    Delete face is the best tool.  Also, preselect all the fillets using the selection manager with a right click first to save time
    Regards,
    Mike LaFleche   @mlaflecheCAD
    Regards,
  • shai_perednikshai_perednik Member Posts: 56 ✭✭
    Worked perfectly thx!!!
