Modifying Imported Models
Bluchip
Bluchip Member Posts: 26 ✭✭
I am a newb at this so keep it basic! I successfully imported a STP file and the model appears to have successfully translated. I did not create the model but it was requested that an internal (concave) fillet be increased. It is the highlighted faces on the screen grab below. I cannot seem to come up with a direct way about this.
 I am certain most here can manage this with ease and elegance!  How should a novice as me go about this?
help.jpg 222.2K
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
    edited September 2016
    Have you tried the modify fillet command (10th from right in your image)?
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    There is separate tool for editing fillets on imported parts:
  • Bluchip
    Thanks for the prompt response.
    I have nearly worn that function out!
    I simply get the red notation show below when clicking green check.
  • NeilCooke
    In that case use delete face then add a fillet feature on afterwards.
  • Bluchip
    We have tried that using the "Delete Faces" command, with or without capping void checked and also with/without the "Delete Radius" checked. Same red results: "Failure to regenerate...."Could not delete selected faces."
    Perhaps I've not imported/translated correctly?
  • fastwayjim
    fastwayjim Member, OS Professional, Mentor Posts: 220 PRO
    I can see in your screenshot above that there are two fillets in two different directions right next to each other. Any CAD tool is going to have a tough time making that radius larger, as it will try to consume the other one. I'm afraid it will need a bit more "massaging". Can you delete the other fillet first, enlarge the one you want ,then put it back in the model? How big do you need that radius to get?
    Or... Can you share the link to the geometry? Perhaps one of us can take a stab at it...
  • 3dcad
    What if you create sketch there and extrude/remove the fillet then add new with bigger radius? There are many options but as @fastwayjim
    mentioned there are some tight places in your model that might require more stabbing than direct editing tools are prepared for.
  • Bluchip
    @fastwayjim
    Will this work?
    https://cad.onshape.com/documents/6afc4cea3304251060dfa79a/w/1e5c589ffc3f7f23bb4552e4/e/d8ad4ec22750270b773944c8
    To recapitulate: We are trying to increase the fillet highlighted in below grab. It is currently some .016" and we'd like to go to perhaps .110" and of course, dress up all the little blends at the fillet terminations.
  • Dylan_Stewart
    Dylan_Stewart Member, Developers Posts: 107 PRO
    @Bluchip
    Can you make the document public? I tried to go in and see what I could do, but it is in view only and we can't even make a copy of it.
    Digital Engineering
  • Bluchip
    @Dylan_Stewart
    It is public now.
  • Dylan_Stewart
    @Bluchip
    Yes, I will try and find some time today to dive in to it.
    Digital Engineering
  • Dylan_Stewart
    @Bluchip so the problem you are having is that the imported model is sharing the fillets on the outside edge as well.
    Choosing only the concave fillet will not give you your desired results as shown
    All I had to do is select some on the convex fillets to get the (assumed) desired result.
    Digital Engineering
  • Bluchip
    edited August 2016
    Well, that does not work for me! I have tried the Modify Fillet command while choosing just about every imaginable combination and order of faces picked...I have never gotten a positive result. Likewise for removing them. Oh well.
    Besides, the result you got is undesirable: Only the concave rads are to be increased.
