Is it possible to model from a 3D laser scan
andrew_hicksandrew_hicks Member Posts: 7 PRO
I have an upcoming job where a 3D laser scan will be taken of an excavator bucket. From that i have to model it and work out wear plates. I think the the file will be a DXF file. Can it be done?
    Thank you very much Mahir i have a direction to go in now, i just was not sure how to go about it.
    jacques_spillmannjacques_spillmann OS Professional Posts: 61 PRO
    @dave_cowden,
    I'm interested in only the first feature of your workflow above: import groups of points.
    do you have a FS that accomplishes this?
    thanks
    dave_cowdendave_cowden Member, Developers Posts: 470 ✭✭✭
    Sorry, I don't. I started one a while back, but I didn't get far enough to make a useful feature. I ended up running into issues with lofted splines , which is quite common with this kind of thing
    @dave_cowden ,
    correction, the first 2 features: import and create 3d spline
