Changing the location of the drawing name text box in a template
Stephanie_Konrad
Member Posts: 2 ✭
I customized a public template, as instructed in the link below.
https://cad.onshape.com/help/Content/templates-custom.htm
However, when I create a new drawing from this template I would like the drawing name text box (Drawing 1 in this case) to appear under the DWG. NO. section of the title block. How can I achieve this? Please refer to the attached picture for clarification.
shashank_aarya
Member Posts: 265 ✭✭✭
Hi @Stephanie_Konrad Press right mouse button on drawing tab and edit the properties. You can see the field part number. In that enter the name as you require. It will take some moment to update in the sheet. Updated text will be in the same position as you require but takes some moment. Please see the below GIF animation.
After this you can delete the old text which was at previous position.7
