how does one convert a 2d point to a 3d point in featurescript?
Member Posts: 14 EDU
I want to give a single point on a flat surface as the center point of concentric circles and I want to be able to select an arbitrary point on each circle.  Then I want to convert those to 3D space so I can use them for various 360-degree operations.  I can generate a 2D point in an arbitrary direction/distance from the point parameter.  However, I can't figure out how to convert that to a 3D point.
